boaterntexas
- Feb 4, 2003
- 254
Is this normall
I buying a boat, and while test driving it, I noticed that it could reach relly high rpms almost 6000.. the boat is a 17' glastron bow rider, I think it whieghs near 1700 lbs, we had a load of aroud 500lbs including gear.. the motor is a 3.0 mercruiser with an alpha one sterndrive. the prop is a 19pitch ss merc marine vengance. after landing the boat I start to inspec the prop better, I look good, I gave is a tug towards me and away from the gearcase.. when I did the prop had some give, only about or less than 1/8" is this normall or should it be a conceern.. on the high rpms, are theese boats geared that low so that they pull better on a load?<br /><br /> the recommend rpms I believe is 4600 @ wot<br />the motor is 1990 3.0 mercruiser, with alpha one sterndrive
