Re: Is this right? (a couple Livewell questions)
I am confused by the tiny baffeled compartment ? Take some bait out of the larger area with a dip net, & put them into the small area for hand grabbing ?
Make VERY sure you have sanded off EVERY JAGGED edge on the edge of each hole !!! Both sides. The fish can easily go shocky if constantly being cut.
Put a piece of Styrofoam into the top surface of the bigger tank to stop sloshing & spilling out of water & bait in bouncy water. Seaweed in there & the smaller space, calms the fish.
A bait tank only nees 2 holes in it. You have both already. ...PERMANANTLY seal all the others. Especially that clear plastic tubing one with NO CLAMP on it.
The DP DT CENTER OFF switch allows you to drain the tank in bad weather. In rough weather.
Put the DP DT switch to EMPTY tank first. Let it empty the tank pretty much.
Then close the top ball valve.
When the pump is dry. Close the lower ball valve.
This double ball valve lets you replace the pump while the boat is in the water. Or to repair piping.
CAUTION !!!!! Putting seaweed or styrofoam into the tank....WILL WILL....clog the pump SOLID eventually. SOOOO
You need a DOUBLE SCREEN on the end of the pipe on the floor. I use 2 layers of screens on tanks. Inner one is Aluminum or Stainless Steel screen sized mesh. Outer is 3/16" or 1/4" same stuff ( from
www.mcmaster.com )
I use a plastic TyRap on the inner screen. The outer can also be TyRapped on the pipe.
You can clear MOST seaweed off the screens by running the pump in the FILL direction if it cloggs up during EMPTYING the tank. I always pick out most of the seaweed first & then hold the hand dip net over the pipe end during draining.
It has been years since I used the tanks. Lures are faster at catching fish. Now I just use a white 5 gallon pail with seaweed & a lid when I have non- fishing people with me.
Rich
