nateo
- Apr 13, 2014
- 352
That is a connector which would go to a switch to turn sound the alarm. The alarm is in a pic below and note the two individual wires. The harness is made for different models and it could be used an inboard transmission temp switch. If I remember correctly you have smartcraft which is digital. The other two wires Green/White goes to the analog trim down switch.
Thank you. Do you recommend I just cut that connector off and wire it up or is there a adapter available?
