Is this trailer bearing ok? (see video)
SWD
Re: Is this trailer bearing ok? (see video)
Not bad......but for the cost just get new.
gm280
That same "play" will be in every wheel bearing, new or old. But when it is installed that play disappears. However, with that stated, I thought I saw a few pits in the rollers. And again, those wheel bearings are very cheap, just replace it...
GA_Boater
I say yes. I saw no burrs or scores on the rollers and as long as the hub race is unmarked, your good to go after packing. The cage gets loose like that in just a few hundred miles of towing and after cleaning all the old grease. The cage does two things, maintains roller spacing and acts a a retainer. I would re-pack and use 'em. If you have concerns, $10-20 depending where you buy.
MH Hawker
I would replace it, the cage is the thing that holds the rollers in place and is made to have slack in it and it is often lose, how ever I saw pits and score marks on the rollers, its done. Any and I repeat any marks of any sort on the rollers is a reason to replace.
BonairII
Ok. I might as well replace them. Any suggestions as to what brand bearings are decent? I don't want to spend more just for the sake of it, but I also don't want to buy a set of bearings that will fall apart quickly.
My local West Marine has a set of CE Smith beatings for $24.99 a set....but I absolutely hate to buy anything there.
GA_Boater
Walmart, auto parts store or a farmers supply store like Tractor Supply all carry trailer bearings.
BonairII
Napa- $39.99 for bearing kit including dustcap
Napa- $12 bucks for bearing seal only
West marine- $25 bucks for bearings/seals(no dustcap)
BonairII
Yup...I tried iBoats first. But price and distance from NY had me looking elsewhere also.
JSGOLD
Nice boat! Those 16' SS Starcrafts are tough and well made..
bruceb58
Make sure you replace the race whenever you replace the bearing.
bret632
NAPA should have them, for the price might as well replace them. you already have it tore down
BonairII
Definitely gonna replace the bearings on both wheels. Going to order 2 sets of bearings, grease seal, dustcap, and cotter pins. Total $37 bucks including shipping
