My bowrider doesn't have a flat/level surface on the bow. Last week, I installed a mount for my Minn Kota Riptide SP (55 lb. thrust) using spacers and isolator bolts in 3 of the 4 holes on the bracket. The second time I used it, the nuts on the bottom of two of the isolator bolts came out of the holes that I drilled (hole size was correct) and the rubber at the neck of the Ts tore. I found out online that many people have had this issue with isolator bolts, even when mounting to flat surfaces.
I bought some Minn Kota quick nuts and remounted it. I shimmed it using rubber washers and nylon spacers. It feels like it's solid when I rock on it and apply pressure...there is a small amount of play between the flange and the first barb on one of the anchors. Do you guys think this will work? I'm chalking the first problem up to the isolator bolts, but I want to be safe. See the images below.
The image viewing area is not as wide as the pictures. There is a scrollbar at the bottom of the images you can move to view the right part of them.
Isolator bolts:
Quick nuts:
Front:
Starboard:
Port:
Top:
Isolator bolts:
Quick nuts:
Front:
Starboard:
Port:
Top:
