Re: Is wakeboarding hard?
i kneeboard and wakeboard.... never had a problem with not having enough time to take a deep breath before crashing on either....will say that it can be scary on a kneeboard for biginners because u will be upside down in the water if your still strapped t to ur board...aka ur head it pointing to bottom. but all u do is undo the velcro. overall id say kneeboard falls hurt less than wakeboard falls. i do back rolls on my kneeboard, and will attempt them on my wakeboard this year. i will say that with either you can take some nasty spills but eventually you kinda get use to it.
For rope id get the ronix R8 mainline its an 80' line with 5- 5' take offs. this gives you lots of options in terms of length and how far behind the boat you are/ finding the best spot of the wake to hit.
Accurate A-line and X-line are good...the X-line is shorter
Proline Vapor mainline
the kind of rope makes a huge difference in the air you get. poly-E line streches. spectra and dyneema doesnt stretch, so you can load the line and this creates pop even without a wake.
Id say any spectra or dyneema from any company would be good. stay away from the ronix frank synthetic though, it has a leather or vinyl cover that is stitched on and it comes undone. most coated line are dipped in some sort of urethane.
you can get either coated line or uncoated, the coated coils easier with less tangles and is alil softer on the hands. personally i dont care which i use, there isnt much difference IMO.
alot of people dog kneeboarding, and im okay with this. its not very popular in terms of big tricks, but thats changed alot in the last decade...kneeboards are getting the same tech as wakeboards with rockers and spines and channels. I believe Ronix is also producing a kneeboard for 2012. It also less expensive to get a pro setup then a wakeboard. I love wakeboarding to, i just like having variety which is why this year im also getting a wake skate
