jonathaninsc
- Aug 14, 2009
- 17
1985 V4 140 looper vro
My motor will surge to full power sometimes, but will usually stutter and refuse to exceed 3k rpm under load. I've rebuilt all of the carbs, new plugs and plug wires, new fuel lines under the cowl. I'm fairly certain I have no fuel leaks. My bulb stays firm, and squeezing during throttling up changes nothing. I've run Seafoam/premix from a portable tank with the same result.
I finally picked up a spark gap tester and found weak spark on my #4 cylinder. Using another plug wire yielded the same result on #4. Is this a bad coil? Or is it possibly something further "upstream" from the coil? Is there a procedure for testing just the coil? I've also noticed I lose signal to the tach occasionally. Can weak spark on one cylinder cause my engine to run so poorly under load?
Thanks in advance for all of your help.
