I bought a used boat, 1992 Maxum 1800XR with a HP Force 90HP outboard. I cannot determine 100% the outboard info (plate is missing) other than I assume its original with the boat and matches a lot of descriptions for the 89-92ish model.
I'm new to boating, but not afraid to get into this and learn the mechanics of the engine..
Having issues when the boat is nice and warmed up, when putting in gear and applying throttle, it will sort of "stall" out. It doesn't completely stall though, but engine just cuts out (sort of like just turning off the key) - doesn't sputter or anything. If I go fast between neutral and forward throttle it will "catch" or something and will go without an issue... Once I get it "in gear" as long as I don't go too low on throttle its fine. It does the same thing with reverse.
RPMs run around 800 during the neutral, very low throttle period. Occasionally it will just stop until I put it back in neutral (if in gear) or restart it (if in neutral).
I plan on getting a compression test and checking over spark plugs/etc... but looking for other advice before I take it into a mechanic and spend more on it if its something really simple.
Otherwise boat seems to run well - I had it going mid-30's and stayed under 5k RPM's (from what I can tell that's the max for this make/model on full throttle).
As you can imagine, this makes loading the boat on the trailer quite the challenge
