I have several questions that I’m hoping you all would be generous enough to help me with. We picked up another boat last year and I’m still trying to work out quite a few things yet. Here we go and thanks in advance!
1) Earlier this summer our VRO pump went out and a shop converted it so now we have to mix our own gas. The mechanic told me the boat would actually run better with it converted as well. And they also replaced the fuel pump as well as he said that was bad too. The boat does seem to top out faster and run better at higher speeds but since they converted it we’ve noticed a few things. 1) It still doesn’t seem to want to start very well, and seems like it could be worse since the conversion. Could any jets, etc need adjustment after the conversion? 2) Now it’s like we have to push the throttle forward a couple inches before the motor seems to engage, this DEFINITELY was not the case prior. 3) Not sure if it’s related but our fuel primer bulb doesn’t ever seem to get hard.
Thanks so much and I would appreciate any advice and please let me know if I need to give more information on anything?
