I recently got a J10ELCTC that hadn't been run for 3+ years.. and no idea on history before that. Got the kits for the fuel pump and carb and installed them as well as a few other odds/ends. Started up pretty easily after that. Has right at about 100psi in both cylinders. Took it for a float test and it ran ok. This is my first boat.... so although I'm an ok mechanic, I don't know about boat motors..
Is there anything I should run through the motor to try to clean it up, or is that stuff just a gimmick? I've seen reference to de-carbing. Or should I just run a tank or so of fuel/oil thru it to burn off anything that might be in there?
Thanks!
Thanks!
