Hey guys,
Need your help again. I decided I needed to add the ability to trim my 84 85hp Force outboard the easy way. So far it has not been so easy!
The original setup used a pin to adjust the trim, and the tilt was controlled by a switch on the dash. I ran accross a Force tilt and trim setup off of a 125hp motor. I have no idea what year this unit came from but it was white in color and was complete except for the hydraulic motor and valve body.
I am probably wrong in my thinking but..........., I had hoped the hydraulic motor and valve body from my original setup would work to also power the new trim unit. Hopefully I just have it plumbed incorrectly because so far my idea has not worked.
The trim unit works great and holds in the position I adjust to with no leakdown. The problem is that the tilt no longers works at all. I have tried both cylinders the new one and the old one and the same thing happens with either one. It is my understanding that once the trim unit is fully extended the tilt cylinder takes over to then tilt the motor the rest of the way up for trailering etc.
When I research the connections to the pump I find more than one combination of line connections shown depending on the model #. Example: Doug Russell Marine shows 5 different models of tilt and trim setups on his online parts catalog.
Since mine is a non-original setup I am confused on the proper line connections needed to make this work properly. The vavle body had two lines to the tilt unit and two additional ports that where plugged. I removed the plugs and I tried to make the connections as shown in my repair manuals but the pictures are not clear enough to see for sure how the lines are routed.
So far, the combinations I have tried have not worked. If anyone has been in my shoes or has any idea's concerning this situation and would like to assist me in troubleshooting that would be greatly apprieciated.
Also need to know what you guys recommend to use as hydraulic fluid in this system. I have been told to use several different things- Jack oil, 30wt non-detergent oil, Automatic transmission fluild, etc.
What do you guys recommend?
