Joe,
1992 Johnson 9.9 J10RENA idles great but only makes a half hearted attempt to get a 14’ aluminum fishing boat up on plane. It ran great when I first got it (used but low time)
A mobile mechanic thought it was burning too rich since leaning the carb needle made it run better. He was supposed to come back and check the carb but never did. I think it burned a gallon of gas going about 2 miles with the throttle at 2/3 trying to clean it out.
FR-yes, it runs on both cylinders
It has a new carb kit (3yrs old but not really used, no pin holes in diaphragm that I could see) and looked over by an auto mechanic, updated redesigned carb cover, proven fuel pump( haven’t tried it yet and no leaks in either pump).
New spark plugs, fuel lines, and use an inline fuel filter.
7/16" spark jump
I adjusted the idle cam screw to be on the mark when the throttle started to open and at full throttle the roll pin is straight up and down. It helped some because at full throttle the motor lost power then came back up some when reduced before. Squeezing the fuel bulb doesn't help get any power.
I put soap suds on the gaskets looking for blow by and they looked ok.
Compression was 122# and 120# the last time I checked.
The float was adjusted per specs in the OMC manual
flywheel key was ok
Tried two different coils off a different motor
Plug and coil wire continuity was ok.
New head gasket
Tried sea foam.
It ran fine before I got that new carb cover. The original roller broke. The new one is an upgraded version and has a plastic pin for the roller.
I don’t have a DVA adapter or timing light.
RacZekp1 wrote:
1. hi,
here is a carb photo taken from http://www.sschapterpsa.com/rambling...lings.html.its model 89, but earlier carb models are symiliar
when botl no 1 is screwed to far, cause throttle leaf in carb troath(there are 3 small holes at upper inner carb wall) open more then 1 hole.
play with screw no 1 and no 2 (I'm not sure how to transfer the photo but he is talking abot the right hand cam adjustment screw next to the link as #1 and the left side as #2
I’ve read the SSchapter several times
My 3 new ideas are 2 new or different plugs (again), a proven fuel pump and what RacZekp suggested but I’m not sure how I would adjust them.
I have to borrow a boat to test the motor.
7/16" spark jump
flywheel key was ok
New head gasket
Tried sea foam.
RacZekp1 wrote:
1. hi,
