Jack for tire changes?
wengr
Hello, my new to me 1996 Escort 20" single axle 3850gvwr trailer did not come with a spare wheel or a jack. How can I determine what is an appropriate style/type of jack, for when I need to change tires, service brakes etc?
dingbat
For working on a trailer I use my 3.5 ton floor jack.
For emergency, on-road work the bottle jack from the truck (Tahoe) works perfectly
MTboatguy
I carry a smallish 1.5 ton hydraulic floor jack in the back of the truck all of the time when I have the boat hooked up as well as a set of blocks and an battery operated impact gun. They don't take up much room and can make the day so much easier in case of a situation that sidelines us.
bigdee
I carry a short length of 4x4 treated lumber with a notch cut in the top to cradle the axle. I wedge it between axle and the ground and drive forward until it raises off the ground.
M2HB
I use a good floor jack at home.
on the road, I carry a quality bottle jack with wood blocks.
US Jack makes some of the best bottle jacks.
superbenk
After having to replace a wheel on the side of the road with the scissor jack from my truck once I decided to buy a 2-ton small rolling shop jack to carry with me. It works great but in hind sight I wish I had gotten a bottle jack instead because it’d be a lot easier to pack & place than the awkward rolling jack.
wengr
Thanks all....I wish to be ready for when that day comes.
dennis461
Yes to bottle jack and couple of small pieces of wood or plywood.
get one of these
found here https://www.iboats.com/shop/seasense-easy-lift-jack.html
and other places like this https://www.hannarv.com/P/1456/Springfield1840046QuickChangeRVTrailerJack
bigdee
robert graham
Walmart sells a small red 2 ton floor Jack for about $20....fits in the trunk of car or most anywhere easily....great little Jack for trailers, cars, trucks, etc., etc.....I have 2 of them!
Sprig
Yep like most I carry a hydraulic bottle jack. Also you should carry 2 to 4 tire or wheel blocks.
H20Rat
I've got a seasense easy lift like above, although modified... I drilled a hole through it, and one of the bolts for my spare tire was replaced with a longer one, so I can attach this on back of the spare and leave it there!
Haven't had to use it yet, but $25 for a cheap purchase just to leave it on the trailer.
briangcc
Craftsman trolley jack and 4x4 block of wood - goes between trailer and jack. I don't tow without it.
I also carry a breaker bar and an extendable ratchet. Never know when you might need a bit more leverage.
82rude
Small 2 ton floor jack for me with nice case so its sort of compact and tidy.
