jack plate?
bigcountry5585
If my motor is too high on the transom, can I use a jack plate for a 1976 Evinrude tiller handle motor? Or cut the transom down?
boobie
Re: jack plate?
You can do either which ever is the easiest for you. Just remember if you have a short shaft mtr now you may want to up grade to a long shaft mtr some day.
Bosunsmate
Re: jack plate?
YEah meant longshaft,
i reckon around here that there are many more shortshafts out there than long shafts to buy
Re: jack plate?
What model motor ?----Extension kits may not be hard to find.----A lot depends on your location.
anzomcik
Re: jack plate?
In the nonrepair outboard section the OP posted a couple threads all with the same problem. Basically his antivent plate is above the bottom of his hull by .5-.75 of an inch and thinks its killing his performance. I have asked for more info and am awaiting an answer
This thread should get everyone on the same page
http://forums.iboats.com/non-repair-outboard-discussions/tilt-trim-637311.html
For the sake of simplicity I have disreguarded this one but he has three threads in the nonrepair section.
http://forums.iboats.com/non-repair-outboard-discussions/jack-plate-637313.html
