jacking transom
nhdukes
Hi. new boating year! new boat for me (1976 mako 20')!my question is this. I have been looking for a used motor for her in the 150 range and finding a used one is not ez.i found a 1998 suz. but the shaft is 25" and i need a 20". Does a jacking plate cause any ill effects and where can i find a cheap uhh inexpensive one. will i need to change cables and all or will the minimal setback and rise in height usually not an issue. thanks and tight lines!!!
Chris1956
Re: jacking transom
Jackplates can be set up to lift the motor 5" or so, depending on the design of the transom. Usually the steering, wiring and cables will work with a jackplate, w/o issue. You really need to get a jackplate and put it against the transom at the right height and see if it works.
