No Title
Hey guys thanks for the help! I got it all sand blasted and shes nice and clean. I think I got it all figured out, how it works and how it mounts. But I have one minor issues now, cant seem to figure out how the nuts go on the shaft? There are 4 nuts and 2 washers left, so are they supposed to be doubled up like I have it in the photo? That seems to be the only way it makes sense but it adds some height in there with 2 nuts, not sure if my hydraulic steering piston will be in the way of adjusting the jackplate height?
jbcurt00: The manual is for a different model, it seems mine is an older obsolete model. Though the manual helped me identify which side goes where, it still didn't help me figure out how it works properly.
fhhuber: Yes you are correct, according to the manual posted above (which is for a different model) shows the BIG side of the bracket to the motor and the smaller one (with vertical slots) to the transom. I thought it would have been the other way around as the bigger section I figured would go against the transom to add strength, of course I was wrong on that one....
gm280: Thanks for the suggestion, yes it would seem it only works one way and i think I got it figured out. I was hoping the bigger side was against the transom but thats not the case with this model and I can't turn it over because it won't work that way as it seems to work with "gravity" and the weight of the motor. If flipped the other way it will be upside down, and the weight of the motor will have no effect on moving it up or down.
