Jammed Shifter?
jparm13
Hi I just came by this post. I am having a similar issue with my shifter. Mine is the type where the whole handle pulls out. When i go to push forward on trottle it stops at about 10 o clock. Its like it is jammed and wont go any further. I don't know where to start. Ideas?
GA_Boater
jparm13 Your new thread. Please read the Help Tip on top of the page. A lot of info about posting in an old thread.
See - No yelling.
SkiDad
might sound simple but (with engine turned off) move it to where it stops lightly and then go and spin the prop... it might just be 1/2 way between gears. you can also try going into reverse all the way and then try going forward. Mine will do that sometimes if I have the engine tilted up.
it could also be a worn out shift rod seal - i replaced one of those last year - cheap fix.
jerryjerry05
IF??? anyone try's to shift when not running??
You need to spin the prop at the same time.
​You can jam the linkage and cause damage.
I guess I need to re-read the post before I post.
​pnwboat is probably right.
The shifter when in fast idle won't let you over rev.
​If it's not revving up?? you need to do a linc and sinc. (in the top posts)
