SpinnerBait_Nut
- Aug 25, 2002
- 17,651
1996 Cherokee 2DR 4X4.<br /><br />Love this Jeep, but need some input on a problem I am having.<br />It started the other morning.<br />It had been running fine up to this point.<br /><br />It acted at first like it was running out of gas, but never quit.<br />Just bogged down real bad.<br /><br />I took it to Advance Auto,(I'm cheap), to have them pull the codes on<br />it and it said, Random Misfire in number 6.<br /><br />So, I bought all plugs/wires/cap and rotor and put on.<br /><br />No good.<br />Next I changed fuel filter. No good.<br /><br />Next I checked fuel pressure.<br />Key on, 44Lbs.<br />Running 48LBs.<br /><br />Turned off motor with gauge still hooked up.<br /><br />Checked in 15 minutes, still at 46Lbs. so not much of a drop.<br /><br />Now this evening we were out in it doing stop and go, we run a paper<br />route, and it started missing and did quit once.<br /><br />Started back up and run like a scalded dog.<br /><br />Now I am stumped. Don't know what else to do except the pump thing.<br /><br />Could it be the #6 injector misfireing at times?<br />How do you check them?<br /><br />Is it possible to change it without dropping the tank?<br />I noticed it came out the front of the tank instead of the top.<br /><br />Sorry for all these questions, but I really need to get it fixed<br />cause I use it ever day.<br />Thanks<br />SBN
