Re: jet vs. prop
Weeds will clog the inlet. Dirty water isn't an issue, but abrasives are.<br />It's safe to idle through water that gives you 12" of space between the pump inlet and sand /Gravel. On plane or WOT, 6" won't pose a problem.<br /><br />The leading edge of the shoe should be even with the bottom of the boat. I've experimented with mine. 1/2" above, gives me 3mph more but cavitates under acceleration. 1/4" above, gives me 1MPH, with no cavitation, plus extra clearance.<br /><br />Your 85hp is now actually rated at about 60 at the nozzle, with the pump.<br /><br />Sucked in a bunch of gravel last weekend. Fourty bucks for a new liner. Came in today, will take 30 minutes to install and shim.
