you definetly know you stuff. i tried what you suggested but got nowhere i've lost the plastic washer from under the brass fitting where the needle thats attached to the float. i need to know if i got the rebuild kit would there be instructions with it. my most concern is probably the s/s valve a guy told me about 30 turns and it will come out. im guessing theres probably some rubber o-rings on this. the other concern is the little round silver plate that has to be removed, i understand this comes oval shaped. i am just concerned that if i get this kit and i mess it up i'll still be in the same boat.
