Engine starts easy, runs smooth at higher rpm’s runs rough at idle and low rpm. Compression is 103 to 105 on all cylinders. At full throttle (and I did already check linkage) it doesn’t have a lot of power like it used to. I found a bad ignition coil and replaced all 4 cause they looked bad. The engine used to go to high rpm and now under load it won’t go past like 3500. Thought it might be not getting enough fuel . I tap the electronic choke and it immediately shuts the motor down. So I’m thinking it getting plenty of fuel. And I know that’s not the right way to do that so don’t hate on me. Lol. Anyway I’m thinking maybe it could be reed valves?? Any suggestions. This boat used to be real peppy and quick. Now it’s a slouch. Made no prop changes. Put new plugs in it last year but I will be checking those again anyway. But last year had same problem even with the new plugs.
