KSBOATNEWB
- Jan 21, 2020
- 17
New boat owner here and sure could use some help. I bought this boat last winter. The gentleman I bought it from said it ran like a top over the summer but he could no longer get it to start. He said he was selling it because he was tired of messing with it. (I feel as though I bought it extremely cheap) It came with a book (pictured) and I attempted to trouble shoot via the book. I bought a new battery, checked the CDI pack with a voltmeter, changed spark plugs, and checked for compression.
When attempting to start the boat the prop turns with force. My boat is in fact stuck in forward gear. I know this motor has the hydro electric shift. Upon further inspection my lower unit has little to no oil in it. I can see where it all leaked out of. (Where the prop meets up to the lower unit. You can see the stains from the attached pictures) the prop actually moves approx. 1/4" in and out of the lower unit by hand on the shaft. The shaft and the locking nut on the shaft has a gap to where the prop meets (Also visable in the attached pictures)
Can anyone give me insight as to what might be missing? A spacer/gasket/something else??? Should the prop move in and out like it does? I am sure my boat wont start because it is in forward gear and the neutral safety switch wont let it fire without being in neutral. I hope it will shift into neutral if I was to fill the lower with oil. BUT I would like to keep it from leaking before attempting to fill it and get it cranked off.
I guess its a possibility that might not even be my issue??? Any insight would be very much appreciated! Looking forward to getting the family out on the lake this Summer! Thanks!!!
