Hi All Can Any Body Help, I Shipped A 190 Ccf Wellcraft From Usa To Uk Last Year & The Engine Will Start Ok But When We Go For A Drift & Restart We Have Problems, Tried New Plugs Etc But Still Happening Can Any Body Help???
Sorry The Problem With Starting Is That After A Few Miles When We Stop For Say 2-5 Mins We Turn Key & It Takes Upto 4-5 Times With Or With Out Throtle To Start Again , I Have Been Told To Use 100-1 Mix ??
know not after it has been running for a while thanks, so stick to 50-1, can you tell me which way the red switch has to point on top of the choke thing on engine ,,, sorry new at this??????
I have the same boat and engine. I also had issues w/ the idling and starting. I tried many different additives. The best one is seafoam. If you can get some add a few cans into the tank. One can treaks 8 to 24 gallons. I use one can per 8 gallons. With this the boat cranks right up and idles well.
Make sure to use 50:1 mix.
