Fastworker
- Aug 15, 2006
- 4
Bought a boat package with this engine. Ran for a few runs and seemed to be running OK - The motor got the boat (like a Boston Whaler 18') up on a plane and up to >25kts. It was a bit difficult to start at times. Boat came ashore from a mooring and some water washed over the enginer but didn't swamp. Started and ran reasonably OK, but wouldn't restart. As I wasn't aware of the history or condition I sent it to a mechanic for some checks. So far, between us we has done the following:
- Cleaned tank and new fuel and 50:1 mix.
- Stripped and rebuilt carbs with new gaskets. Did not strip Reed valves.
- New Fuel lines
- Using pre-mixed fuel and isolated two-stroke feed
- Compression is between 95 and 108lbs
- Spark in all cylinders.
Right now I have it starting OK in the water - Idles OK, but sounds a little uneven. Motor rocks a little back and forth a little. Is this unevenness typical for a V-engine?
Problem is when I engage reverse it just cuts out. Similar with forward unless I up the rev with the idle lever.
One other point, there is a trickle of oil running down the outside of the shaft - Any thoughts on this?
Any suggestions where I go next?
Wondering if there is something I should check about the detailed spark timing and advance etc.
Anything else. I don't know the service history of the engine except that it was running reasonably OK recently and that the ignition coils on one side had been changed last year.
I need to get a workshop Manual ( Any suggestions which I should get? - Any available by e-book?)
I've already missed most of the summer season, so really keen to get on the water to get things right for the start of next year!
Any help greatly appreciated!
- New Fuel lines
