Johnson 115 bog
yzfsxr
My 1999 Johnson 115 bogs on takeoff. Works fine otherwise. Makes it tough to pull up skiers. Any ideas? Thanks
Brew
Re: Johnson 115 bog
Having a similar problem with my Evinrude 140. Cleaned up my carbs and installed carb kits (new gaskets, floats, needle valves), which helped but did not eliminate the problem.<br /><br />I replaced the fuel line, filter, and primer bulb, but haven't had a chance to take it out on the water since. However, the motor sounded a bit better on the muffs in my driveway.<br /><br />Basically, I'm assuming I have a not enough fuel (too much air) problem. I'm hoping the old, somewhat brittle/cracked, fuel line was leaking air into the system.<br /><br />Hope that gives you some ideas to start with. Good luck!
epresutti
Re: Johnson 115 bog
Had similar problem with Johnson 140 (82), was the water separating fuel filter. Pulled the filter, poured into a glass jar and waited for it to settle out. Half was water half was gas.<br /><br />From then on always carried a spare filter. It turned out I had a pinhole leak in the fuel tank which the water from the bildge was getting into.<br /><br />Hope this helps.<br /><br />Safe boating to all.<br /><br />Cheers.<br /><br />emp.
