I have a 1983 Johnson 115 hp V4 (rebuilt)
Compression is 110 on all 4 cylinders, I am getting fuel to all cylinders, fuel bulb is staying tight, I do have spark on all 4 cylinders, I have swapped spark plugs and wires, I have switched coils with no change, I have switched power packs and still only #2 has the weak/intermittent spark. I have determined this by doing the drop test and looking at the plugs. When I drop #1,3,&4 the motor drops considerably and when I pull # 2 and replace there is hardly a difference.
When I first to take off WOT I can tell all 4 fire for a second then I drop the #2 cylinder. I am going to get new plugs today but I doubt its gonna help but it cant hurt. Last week the #2 spark plug boot had worn through from contact with the cowling latch and was arcing to the motor. I could hear the ticking so I tapped it and it stopped. Could It have done damage to the Stator, Trigger when arcing? Seems like the coils, wires, plugs, and power packs are good to go. As I said I am getting spark on the cylinder but It is either flooding or not strong enough of a spark to handle WOT. Also It does miss a bit (intermittent) at idle. Please help.
Best Always,
Ryan
Best Always,
Ryan
