Johnson 115 Trim Pump problems
usnguenther23
Alright need some help. I am having issues with my trim wiring system. I replaced the entire Hydraulic system on my Johnson 115 thinking the pump went bad and then had other issue while just trying to replace that. But now I was not getting a hot wire to either trim switch on the motor or on the throttle. I decided to direct wire the hot from the battery to the switch on the throttle and I have power running back through my blue and green wires however I am not sure where these run too. I looked at the bottom of my relays and dont see that same color. Does anyone know where the blue and green wires from the trim switches run too. And has anyone had this problem before. I fear I am missing a fuse or something I haven't checked.
Other items to note I replaced both relays. I get power to the large red wire into the relays. I do not hear any click or noise from the new relays when I press the trim switch.
I really think this is a problem with the signal from the trim switch to the relays not allowing them to operate.
Post model of the outboard motor.-----And does the tilt motor use 2 wires or 3 wires ?
usnguenther23
Tilt motor is two wire green and blue and Switches are three wire hot, blue, and green. Model of motor J115VLSSS
