johnson 115 wined's up slow
t5535
I have a 1990 johnson 115 v4 it seems to run fine but when you hammer it it does not wined up very fast. it has a 17 pitch stainless steal prop. could old plugs or maybe bad gas cause this? or maybe carbs need cleaned?
emdsapmgr
Re: johnson 115 wined's up slow
Yes, all of them. I'd probably check the compression and spark first. If you know you have good compression and a hot spark on all 4 cyls, then you can start checking for fuel issues.
tashasdaddy
maybe you are pushing more weight than you think. could you boats foam be waterlogged? i have taken as much as 500 lbs of wet foam out of boats.
t5535
Thanks a lot for the replays. I am gonna do a compression test tomorrow. I just bought new plugs and wires for it. water log that makes seance but how much foam is in a bass boat? its a bayliner bass trophy 18ft. plugs did not look good and wires were horrible so I am hoping that is what it is.
