Johnson 115 wont idle
Pender
I have a 1995 115hp Johnson that will idle fine in neutral but will stall as soon as i put it in gear under load at idle. When I put it in gear and throttle up she will run at speed but when i return it back to idle in gear she stalls.
Bob_VT
Re: Johnson 115 wont idle
Do you have a tach? What is your idle in gear RPM's? Might just be a cable adjustment
