newtong_ware
- Sep 18, 2005
- 59
I've been working on my 115hp '76 etl trying to get it running more reliably. I have rebuilt the carbs and things were looking better. Now the port cylinders do not fire. <br /><br />I did replace the kill and start switches, and according to old posts I checked for volts at the blk/yel wire at power pack. about 2mV DC. Pretty darn low. With kill switch lanyard in place the circuit to the power pack is open when ign key is on and closed when key is off. With lanyard pulled, blk/yel grounds out period. I had previously checked the ops of the start switch(good) and verified the kill switch ops (good). So I do not think this is a problem....?<br /><br />I did the sensor coil high and low ohm tests and all was within specs.<br /><br />I checked the coil impedance through the coil and to ground on the port coils vs the starboard coils (primary)and all were the same. The lower cyl coil on the port side was different from the other 3 and it looked like it had been getting warm where the hi tension lead enters the coil.<br /><br />I cannot do any of the other tests unless I can come up with the neon tester referenced in the manual.<br /><br />So I guess my questions are these:<br />Any suggestions on other things / tests to consider?<br />Where can I get the neon tester and how much about?<br />Whats the best source for coils and powerpacks if I decide to just get them all. <br /><br />I have had the boat two years now and it is either going to act like it should this year or I might do something rash with either a chainsaw or gasoline or maybe even both.
