My 1992 johnson 120 has a constant warning whistle blowing. This was happening to me on and off at the end of last season. I just brought it out of storage today, started it up, and the whistle is blowing--but here is the thing that I dont get--the whistle blows constantly before the engine starts--that is, with the key in the RUN position.
The constant whistle I guess is one of two things--A)over heat--which doesnt make sense because the whistle started before the engine was started or B) fuel restiction--which puzzles me because the engine runs well.
I figure it is a fuel problem or a problem with the warning system itself.
Questions:
If the system were to signal a fuel restriction, wouldn't the whistle start only after the engine started?
What would malfunction in the warning system to cause the whistle to blow constantly no matter what?
What type of fuel restriction would alert the system before the engine started?.
Any help would be greatly appreciated as you can see I really dont know where to start.
The engine is on a 1993 four winns 180 freedom
Questions:
