My Johnson 120 (model J120TLESB S/N G02569565) has been having an intermittent issue. It will run for 10 minutes to 2 hours (the longest I've run it without shutting it off) , but when it dies it will not re-start for 10 minutes to 3 hours. It always starts right up after extended stops, like overnight. I've installed a fuel/water filter that didn't solve the problem. I've checked venting the tank, but that didn't help. The fuel level doesn't make a difference. I was able to remove a plug and ground it while another person cranked the engine and didn't get any spark. I was also holding the plug when it finally started and can positively verify that there is adequate spark when it finally decides to start! How do I diagnose the faulty component? Is there one component that is more apt to cause total shutdown? Thanks
Marlin
Marlin
