On a looper its normal for a small ammount of fuel to accumulate in the airbox. Theres actually a rubber seal in the bottom that seals it so it wont leak. <br /><br />If your airbox is filling up past the seal then its tiime to find out why. If youre running with the cover off you may get some when you tilt the motor.
