Johnson 120 motor weight
aw1575
Can someone please tell me what a 1985 Johnson 120 weighs. Thanks.
roscoe
Re: Johnson 120 motor weight
306 lbs long shaft<br />315 lbs for the extra long 25" shaft
aw1575
Thanks Roscoe. That's a lot less than I imagined as I figured that the older technology would weigh more than the modern outboards. I'm looking at repowering with the 1998 115 Mercury which weighs 350lbs so the difference is about 3/4 of a tank of gas.
wilde1j
Alan, try 365 lbs for 20" shaft and 370 lbs for 25" shaft. The OMC brochure for that model year had incorrect weights, which must have been Roscoe's source.
93bronco
Ensign
in the nada listing it shows the correct weight starting in 1986.
