Johnson 120 won't accelerate past 10mph
Jake Blood
HI all.. first time poster here and first time boat owner..
I just recently purchased a 1977 venture tri-hill with a Johnson 120hp on it. It also says V4 VRO on it.. if that might mean something to you..
When I got the boat, it ran great.. would reach about 40mph.. I was happy.
The guy I bought it from told me that for the 8 gallon tank I have, he adds one 16 ounce bottle of marine oil to it, and that is the correct mix. I ASSUME that is correct since it did run fine.
I have had this boat out about 5 times.
The secod time I brought it out.. It was with a buddy. We stopped and put fuel.. 3.9 gallons.. which cost 8 dollars. In his mind it registered as 8 gallons, and he put a full thing of oil. ( 16 ounces ).. the engine would not get over 10mph for that trip...
The next time out.. I put just gas.. about 4 gallons.. to compensate for the excessive oil he put in... The boat ran sluggish at first, but then ran great for the remainder of the third and 4th trip...
The 5th and last trip.. the engine is back to running sluggish.. It will sound smooth and run great up till about 9 mph.. as soon as I push it further it bogs down.. then after several attempts, it got up on plane.. for about 100 yards, then bogged down and would not go over 10mph...
When I got home, I removed the plugs and they were drenched in oil.. black.
I wiped them off, put them back in, checked the fuel filter.. clean as a whistle.. Not sure what to do next..
Someone told me there is a 'high speed injector' that might be pluggged, and that I need to take the carbs apart and clean them and put them back together.. etc...
One, I do not know how to do this... Two, what might that cost.. Three, is there some other lower cost alternative I can try first?
Thank you so very much for any feedback I might get.. as a first time boater I am starting to wonder if this is for me..
