Any operator staring at the Tel tale for failure instead of watching where the boat is going, could be facing major Legal Problems quickly.
A Pressure Gauge needs constant monitoring, as does a Temp Gauge. A Horn at least gets your attention right now, provided it didn't Scare you overboard. Used in conjunction with Temp and Pressure Gauges, and Tel tale would give a lot of info as to determine what the problem is, if there even is a problem
