Maxum21
- Mar 8, 2005
- 219
hey guys, i recently mounted a new water/fuel seperator for my '96 Johnson 130 since the boat didnt have one. The water/fuel filter has 3/8" fittings. The old existing fuel line was 1/2" from the tank fitting to the primer bulb. The line from the exit of the primer bulb that runs up into the motor was 3/8". I'm not sure why they would use two different line sizes??.. I'm going to replace the fuel line off the tank. I already bought the 3/8" line. Will i be ok with the 3/8? i rather not have to pull the fittings off the seperator and buy new but if the 3/8 wont be adequate i will. what do you think?
thanks
thanks
