Promaster 210
- Aug 29, 2007
- 20
Hey guys and gals, I know this question has been beat to death, but I am really tired of hearing the same answers over and over again. All I keep hearing when I ask the questions about VRO2's is to bypass it and start mixing my own fuel. Well I do not want to do that and am here to tell you why. My boat has only 65 hours on it and I dont think I should just bypass an option without giving a serious attempt at a educated , proper repair.
The engine is a 1996 130 w/ VRO2 and as I stated only 65 hours of operation. I have done all the tests as described in the service manual and have listened to advice from all around the world on my "no oil" light coming on. The VRO2 system is working and the engine continues to oil and it runs great. I have replaced clamps, oil lines, cleaned the oil tank and replaced both fuel and oil primer bulbs, found a leak on the primer solenoid and fixed it, replaced the plugs and checked compression and have done a crank vac test. The boat runs for 4 hrs avg and then the dang buzzer goes of for 10 seconds exactly. Last time,I saw it was still smoking and oiling, so I said screw it and ran it back to the ramp. The light went off halfway across the lake, then came back on as I was loading the boat. Does anyone know what could cause a "false alarm" like this and what I might do to keep it from happening? I run SeaFoam in each tank when I fill up. Can it foam up and cause a NO OIL alarm condition? I have read it can be caused by the fuel system as well as the oiling system. Some have even suggested that my tach is bad, but I tested each alarm as described (in the service manual)and everything seems to function as it should. I dont mean to come across as bitter, but I am at my wits end. I did dump the oil rez and change the sock filter and fill'er up again.
