I have a 1995 Johnson 130 v4 Outboard that idles great, no choking, coughing or misfiring. I can rev the engine up with the throttle lever and everything is fine. When I put the engine in gear and advance the throttle, the engine rpm does not increase. The drive goes into gear and the prop drives the boat, but everything stays at idle speed, even at full throttle postion. Take the engine out of gear and advance the throttle the engine rpm revs up great.
This began after a day on the lake where everything was running fine. It starred to rain so we went back to the dock to get the canopy out of the truck and put it on the boat. When we backed out of the dock and put it in gear, that is when this problem started.
My local dealer said he thinks the carbs are gummed up from old gas, but it only does it when in gear. Looks like if it was problem with old gas or bad fuel, there would be some misfiring when not in gear or else at least rough idle. But when it is not in gear, it purrs like new.
I don't see any vacumn lines loose or anythiing obvious. Does any one have any suggestions?
Thanks,
Rick
Thanks,
Rick
