I have found a problem with a 140 Johnson 1986, The motor was starting OK. Idle OK. WOT OK but running rough at mid throttle.<br />Investigation revealed that the metering tubes in the carbys had started to disolve, the carbys and metering tubes are plastic on this model.<br />Has anyone come across this problem before, I am not aware of ethenol use in this area but that is a possibility.<br />It appears that the metering tubes are not available as seperate items but I have to replace the carbys.
