LittleboatPhil
- Jun 26, 2021
- 4
Greetings all, long time reader first time poster. I’ll get right to it, a fishing buddy of mine has a 1988 Johnson 14spl that has got me stumped. Engine starts on 4 or 5 pulls, runs strong, idles down nicely, then overrevs and stalls. I pulled the hose on the primer circuit and it takes about 8 pulls on the plunger to get gas to come out which makes me think float bowl is empty. Primer bulb stays hard while running, and squeezing when it starts to lean out doesn’t stop it from stalling, in fact gas will start to drip out the carb body but still stall. I didn’t have time to pull carb while I was visiting but does something as simple as an improperly installed float/needle valve sound like a possible culprit? It will probably be coming home with me to work on this week, hopefully this thread will help someone else since there is such a sparsity of info on these 14’s
