Johnson 150 1997 2 Stroke Fuel Mix
Crashtackle
Hi,
My outboard does not have an oil tank and I mix the fuel at 50:1.
Is that okay or should it be at a lower ratio.
CT
trendsetter240
Re: Johnson 150 1997 2 Stroke Fuel Mix
50:1 is the correct fuel mix for that engine. Use only TCW3 rated 2-cycle oil and you will be fine.
cheers
