Re: johnson 150 gt
The factory does not offer rebuilt kits for those pumps. Probably is a reason the factory doesn't.. Perhaps the kits you used don't let the pumps provide the fuel it needs. Here are other things you can check: 1. the anti-siphon valve on top of the tank may be sticking, causing poor fuel delivery. 2. The ball valves in the hose can act up, exp if the hose uses is not new. For instance, make sure the hose bulb arrow is pointed in an upward direction. If it's downward pointing- the valves can act up. 3. Only use 3/8 hose line. 4. If you used any bulk fuel hose under the cowing, make sure it is not kinked. Bulk hose will kink (restriction) if it bends a tight corner. Not like factory formed hoses. 5. Make sure the plastic fuel pickup inside the tank is not loose on the hose barb at the top of the tank. 6. Probably not a problem, but just in case-take a fuel sample to check for water. 7. I doubt you are using any 5 year old grey merc fuel line. If by chance you are, switch it to some Bombardier 2013 fuel line.
