I am doing this for someone so I dont know what the model number is but I know that it is a 1989 johnson 150. It was not running right so he took it to the shop and the man change all most all the electric things on the motor. They change the power pack, stator, rectifier, spark plugs, checked for spark on all plugs. He got it back and took it to the lake and it ran better than it has in a long time but one day it started some problems. He got home checked the motor and seen where the man did not tie down the stator wire so some had been cut. He spliced them back togeather. NOW the boat will not idle. You can get it to go by raising the rpms and put it in gear before it dies but then the boat will not get up on plain. It gets to about 2800 rpms and stops. Take the boat out of water and tottle it up and it will go over 2800rpm and you can let it stay at about 2500rpm for how ever long but once you tottle down to idle it cuts off. One more thing we took all the gas out and tried new gas. If anybody knows anything the help will be greatful THANK YOU VERY MUCH
