Johnson 150 Won't Start
ctboater
My 1996 Johnson 150 won't start. It was running great today for about an hour, didn't notice anything unusual (sputtering, loss of power, etc.) Brought it down to an idle, and it cut off abruptly. I noticed the following:<br /><br />1) Plenty of fuel (looked in tank, bulb gets firm, smell of gas when cranking).<br />2) No alarms<br />3) Starter cranks away, but engine never turns over.<br />4) Steady stream of water from outflow when cranking<br />5) Oil tank full<br />6) Plugs look fine, checked all the connections<br />7) 13 AMPS in battery<br /><br />Any ideas? All thoughts are appreciated.<br /><br />Thanks,
ctboater
Re: Johnson 150 Won't Start
I should also add that I don't think it was flooded, because the problem persisted for about 3 hours, and I tried the fast idle to clear the pistons.
Walker
Fuel/air, compression, spark. Need to find out which is missing.
Valv
Ctboater, have you checked the lanyard switch ?<br />It's the red cord emergency that hangs on remote or near dash.<br /><br />Try to pull cable out then back in, to see if it works. I had same problem 3 days ago, I had to let boat drift to shore, wife went and got trolling motor (which I forgot), while waiting, I unclipped cord, messed with switch, and...wroom it fired up as soon as I turned key.
SeaMasterZ@aol.com
you sent the WIFE to get the spare kicker????<br /><br />damn, shes def a keeper, lol, did you have her row the boat to shore as well?<br /><br />stroke<br /><br />stroke<br /><br />stroke<br /><br />hehehe : o)~
Valv
Yep, she's been a keeper for 13 years now, and going for many more, you should see her backing up trailers, she's an expert, even with a 26footer.<br /><br />I used my fishing net handle to push boat last 20ft to shore.<br /><br />Remember, always buy a net with a long handle, you never know what could happen.... ;)
ctboater
Thanks for the advice, everyone. Walker, I am new to this, but have bought the manual, and will try to narrow it down to fuel, compression or spark. <br /><br />Valv, the kill switch lanyard was the first thing I thought of, as that has happened to me in the past.
