Re: Johnson 150hp Idle
What is the idle set at? Should be 650 to 750 RPM under load in gear.
Is it running for a certain amount of time, then dying off? Will pumping the fuel primer bulb keep her running?
What about spraying pre mixed fuel into the carb throats? Choking it? The carbs likely need to be bathed/rebuilt. See the FAQ for a thread by Tashasdaddy regarding this.
