Re: Johnson 155 Trim/Power tilt Motor
Hi Mike..<br /><br />I am doing just that right now on an older Johnson, its a nightmare getting the bolts out.. particularly the big one that runs though both rams at the bottom.<br /><br />the two smaller bolts at the top of the ram are just as bad, mostly because there is no easy way to get to the inside of them to apply any force. last time I did this I was forced to drill the head off one of them and use it as a punch to push the other one out..<br />This time I am trying to avoid doing that.<br /><br />its not easy,, but it can be done.. all you can do is soak in lots of penetrating oil, use some heat on the surrounds, and hit it, (the bolts), hit them hard..<br /><br />I am 3/4 of the way through this one, and I have yet to damage any of the bolts, it would seem that you get better at it with pratice
<br /><br />I am taking my whole unit (both rams, pump and all piping out in one unit because it seems like it might be better to not disconnect anything till after I get it out and clean it up.. so far so good.. sorry I can't be more specific to your setup.<br /><br />rgds<br /><br />Frank
