Conway Cox
- May 7, 2009
- 3
I have a Johnson 15hp 1988. I bought it rebuilt a year ago. It has worked great untill now. It starts and idles fine. even goes into gear and runs fine at idle speed. When I give it gas it starts to go but then loses rpm. Does'nt really stall out but slows down in rpm. It will not reach full throttle. Seems to do the same at any speed. Runs fine at low speed but anything more and it seems to not reach full speed and will run at a lower speed roughly. Sometimes stalls when running at high speed and then throttle down to idle speed. I've replaced the fuel pump and did not help. Next step is cleaning carb but don't think is the problem since carb was rebuilt a year ago.Dirty carb? Compression? Spark plugs? Points? Coils? Please Help!
