Johnson 175 lower seal rebuild
John_Dennis
I have a surplus Johnson Lower that I want to rebuild and sell to finance another project. I bought a boat with a bad motor that died when one of the carburetors got fouled with Eco-Gas. I kept the lower as a spare because it fit my existing outboard. It has been in the attic for 10 years.
I believe it came off of a 1998 Johnson 175 V6 carbureated engine.
The large O ring in the hub is leaking. I want to replace the seals so that the unit is ready to use by the next owner.
I am attaching some detail photos in hopes that someone can help me verify the model so I can get the right parts. I am also looking for some info on replacing the seals.
Thanks
John
jakedaawg
Just to do the large o ring?
Simple, remove the two cap screws that hold the keepers in place. Remove the keepers. Thread in a length of 5/16"?18 threaded rod into the two holes. Put your puller over the rods and remove bearing carier. Replace o ring and reassemble. Incredibly simple.
John_Dennis
Thanks Jakedaawg, do I need to have the shifter in a certain position, or will the gears and prop shaft remain in place?
jakedaawg
They should remain in.place. reverse gear will come out with carrier..just seat it all back into place with a leather mallet. Coat bearing carrier surface with permatex form a gasket. Not the part that will contact l.u. fluid. Just the outside edge surfaces between housing and carrier. Seat it with a soft mallet.reinstall keepers. Use a little blue thread lock at the threads and permatex at the heads.
