Johnson 1952 TN28
F_R
No Title
Most are, from an Evinrude dealer willing to help. Many part numbers have been superseded by updated numbers. For 4-digit numbers, add preceeding zeros to convert to 6-digit. 41-62 becomes 004162. Not available as a kit, you have to pick out and order individual parts
F_R
No Title
This parts list is easier to read, same gearcase, but be careful. A few numbers were Gale-specific.
neverthought
Thank you for the info. Also, I noticed they call it a grease seal, what goes in there, gear lube or grease?
neverthought
Thank you for the info. Also, I noticed they call it a grease seal, what goes in there, gear lube or grease? And what do you mean by "gale"
flyingscott
lower take 80w90 on those look on ebay for the seal also call a dealer it might have a superseded part #
neverthought
That's not the correct seal on eBay, the one i need is the gear lube oil seal near the water pump. I found the one for the prop shaft and i thought it was the same for the other but its not the other one is a bit larger.
HighTrim
Sorry didn't really look at the pic. That is not what you need!
Im sure I have a seal, Ill look for ya. Post a wanted ad at aomci.org in the classifieds, someone local to you might have one.
neverthought
Hi, i never did find the correct oil seal for my TN-28
Still looking for:
johnson tn 28 part number 302302 seal
Its #15 on the parts list:
fetch
flyingscott
Do you have any numbers on your current seal sometimes they can be cross referenced. Otherwise take a micrometer measure the shaft and the housing where it goes and find a seal and bearing company they can usually match something up for you. Or you need to find a dealer ship that goes back before 1968 they hopefully will have the parts fiche needed for that motor
F_R
302302 is available from Evinrude dealers. If they don't have it, they know where to get it.
